FTTP installed today but no router has been sent?
- My Order
- FTTP installed today but no router has been sent?
- « Previous
- 1
- 2
- Next »
Re: FTTP installed today but no router has been sent?
02-07-2025 2:40 PM
Looks like I may be in the market for a new router
The Hub 2 that's on its way should be fine, especially since ..
I have UniFi access points for WiFi, so currently don’t use the router for WiFi, all turned off.
02-07-2025 3:00 PM
Maybe a next gen ASUS (no learning curve for me) or something that supports openWRT (learning to do)….
Thanks for your help and suggestions.
02-07-2025 3:46 PM
https://amzn.eu/d/6osasfk
Openwrt is the base os, which you can get access too if you want to dabble
03-07-2025 8:34 AM
If you're looking at the Flint 2 (linked above), then it's also worth considering waiting a few weeks for a Flint 3.
03-07-2025 10:21 AM
Might be tempted myself!
03-07-2025 10:32 AM - edited 03-07-2025 10:33 AM
Spec looks good on paper, only problem is its a Qualcomm QCA 50xx SoC which means its not likely to get official OpenWrt support in the short term.
04-07-2025 9:42 PM
Be careful to check the specs, not everything is an upgrade versus Flint 2.
04-07-2025 10:00 PM
The GL.Inet GUI/feature set is pretty decent even without the vanilla OpenWRT support. I've one of their Beryl AX travel routers for when I'm out of the country and it's fab. Also have a Flint 3 to play around with and it's good, but some corners have been cut with the hardware (understandable for the price) e.g. it's superior to the Hub Two in terms of standards but has fewer antenna.
- « Previous
- 1
- 2
- Next »
- My Order
