FTTP installed today but no router has been sent?
Fixes: 524
Re: FTTP installed today but no router has been sent?
Looks like I may be in the market for a new router
The Hub 2 that's on its way should be fine, especially since ..
I have UniFi access points for WiFi, so currently don’t use the router for WiFi, all turned off.
inabox
We’ll see… I like the fact I can add extra functionality into my router… advert/spam site blocking, OpenVPN server, has an api to extract data into my home automation platform to take action on etc….
Maybe a next gen ASUS (no learning curve for me) or something that supports openWRT (learning to do)….
Thanks for your help and suggestions.
mystreet1
Fixes: 4
This is a good one to have a look at
https://amzn.eu/d/6osasfk
Openwrt is the base os, which you can get access too if you want to dabble
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
bobpullen
Fixes: 327
If you're looking at the Flint 2 (linked above), then it's also worth considering waiting a few weeks for a Flint 3.
mystreet1
Fixes: 4
As @bobpullen posted, look at the flint3, especially at the price £119.30, which is a great deal.
Might be tempted myself!
Fixes: 524
Spec looks good on paper, only problem is its a Qualcomm QCA 50xx SoC which means its not likely to get official OpenWrt support in the short term.
bobpullen
Fixes: 327
Be careful to check the specs, not everything is an upgrade versus Flint 2.
bobpullen
Fixes: 327
The GL.Inet GUI/feature set is pretty decent even without the vanilla OpenWRT support. I've one of their Beryl AX travel routers for when I'm out of the country and it's fab. Also have a Flint 3 to play around with and it's good, but some corners have been cut with the hardware (understandable for the price) e.g. it's superior to the Hub Two in terms of standards but has fewer antenna.
