Email to say product change complete
- My Order
- Email to say product change complete
12-10-2016 7:45 AM
My husband called plusnet last weds to request a change from ADSL to fibre. We received the router Friday and plugged it all in - I know the change wasn't completed then, but also knew the router worked on standard ADSL, so though may as well get it connected. We had been given no dates for the product change to complete other than "approx 10 working days". Which should be 2 weeks from when we called.
Fast forward to today (1 week from first calling). I get an email to say the product change is now complete. Bit quick I think, but heyho! Switch router off and switch back on and no change in speeds whatsoever. Has the change completed? Have I done what I need to do with an already setup hub1?
Final question - if the order isn't "complete" why send an email to say so?
Helen.
Re: Email to say product change complete
12-10-2016 7:49 AM - edited 12-10-2016 7:51 AM
There's dozens of posts on here very similar. I suspect the e-mail refers to the change in admin to a new account not a physical change to a fibre connection
To be is to do - Kant
do be do be do - Sinatra
12-10-2016 7:55 AM
It is ridiculous that that email hasn't been improved.
It seems Plusnet are far more concerned with getting more customers than keeping their existing customers happy!
12-10-2016 9:22 AM
Welcome to the community forums @hellyl
Apologies for any confusion caused by the product change completion email. As @PeterLoftus has said, this has unfortunately happened to quite a few people and I have been pushing this towards the right people to get this looked in to and improve the communication around the completion notification.
I've checked your order and it's due to complete on 18/10/16.
You shouldn't need to make any changes with the Hub One when the fibre order completes, it should just work.
I ask myself this every time another one of these threads come up. Again, I do sincerely apologise for any confusion caused. I'll pass further feedback on regarding this matter and continue to push for improvement in this.
12-10-2016 9:25 AM
Thanks for the replies - the 18th is definitely around the date I was expecting.
12-10-2016 1:23 PM
It isn't obvious, but if you log onto the member centre, follow the "View Your Questions" link and look at Closed Questions, you may find all sorts of interesting information has been put there without you knowing about it; such as your expected activation date and so on. It seems to be used by PlusNet as a sort of audit trail of everything to do with your account, except they don't tell you it's there
12-10-2016 1:30 PM
Another place to look is the BT Broadband Availability Checker where you should see an open order with a completion date.
That's when your broadband goes live
12-10-2016 1:38 PM
I have got questions in there answered etc, I also posted in there replying to our product change - similar to my original question here and the reply was there will be fluctuations in speed for 10 days after the product change and if after 10 days the speed isn't expected contact customer support if I am not on fibre how can there be a change in speeds - honestly you can't make it up
12-10-2016 1:42 PM
I'd not noticed then when I checked the order completion date earlier. Thanks for pointing that out.
Sending an email to their manager now.
on 12-10-2016 2:01 PM - last edited on 12-10-2016 3:02 PM by Mav
they have not long replied that, I was a bit short in my reply back - I apologise
Moderator's note by Mike (Mav): Full quote of preceding post removed as per Forum rules.
12-10-2016 2:12 PM
12-10-2016 2:20 PM
thanx, will do. Am sure it will be fine.
- My Order
