Early activation
theycallmethor9
Early activation
wonder it would be possible to activate my broadband early?
I have a strong broadband sync.
I'm able to connect to BT_test_user both at startup and plusdsl.net
I was briefly able to resolve plus.net the other day.
I'm sure this is just plus net not authenticating my account as BT seem to have done their end of things.
Many thanks.
Stuart.
2 REPLIES 2
Mav
Fixes: 512
Re: Early activation
Moderator's note:
Thread moved from Broadband to My Order.
Forum Moderator and Customer
Fixes: 1,586
Hi Stuart.
From what I can see your order is still in a committed status on the wholesale systems, which should complete tomorrow. Though from what you've said, it does sound like the work has been done so I'll activate your account on our side.
If you're unable to connect in a few moments, it's possible that not all the work has been done, so I'd recommend waiting until tomorrow.
Hope this helps. -Anoush
