Dont move to my new place for a few weeks - how important is this message?
Matt795
"Our initial checks suggest that the Openreach ONT device at your property is currently powered off. We'll continue to progress your order but if you are able to, we would recommend that you power on the device at your earliest convenience."
Do i need to arrange to visit and turn it on? I'll want internet sharpish when i move (within 2 days).
2 REPLIES 2
Fixes: 529
Re: Dont move to my new place for a few weeks - how important is this message?
It would be a good idea to at least visit and check that the ONT is present and working by powering it on, at least temporarily.
If it isnt working then there would likely be a delay to get an Openreach engineer out to replace it.
Fixes: 1,491
Moderators Note
This topic has been moved from Full Fibre to My Order
