Do i have to drill the wall?
febrxyz
hi everyone,
Recently I rented a flat and it was using BT broadband for their internet. But i found out that plusnet have a better offer so i decided to change the broadband company. However, im not sure if there is a BT socket in the flat. Does anyone know if you used BT broadband, is there a BT socket already or not?
7 REPLIES 7
Legend
Fixes: 255
Re: Do i have to drill the wall?
If the previous tenants had broadband, there must be a master socket - you can't have internet without a phoneline,
Gel
Aspiring Champion
Fixes: 29
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Order
198kHz
Fixes: 41
Welcome to the forum.  🙂
If the flat has BT broadband, there will be an Openreach master socket. That would remain in situ whether the ISP is Zen, Post Office, Plusnet or whoever, apart from Virgin.
Murphy was an optimist
Zen FTTC 40/10 + Digital Voice   FRITZ!Box 7530
BT technician (Retired)
febrxyz
Will the engineer come?
Hi everyone,
If i want to purchase the fibre broadband, is the company only sending me a mail with the router in it or they will send an engineer to my flat? If yes, what is the engineer going to do?
Fixes: 1,483
Re: Will the engineer come?
Moderators Note
Topics merged
Legend
Fixes: 255
@febrxyz wrote:
Hi everyone,
IF you decide to get FTTC (thought you'd already made the decision?) you should not need an engineer visit unless you have no BT master socket. The Hub will be delivered by Royal Mail - it is just plug-and-play.
