Delaying connection
Dushyantor
Delaying connection
I've received my router and been moved to EE, but will not be at my property for the next six weeks. Can I complete the switch seamlessly on my return in September?
6 REPLIES 6
Fixes: 389
Re: Delaying connection
What service are taking fro EE? Although that is slightly irrelevant. Providing nothing goes wrong , all you will need to do is substitute the EE hub for the PN  one and it should 'just work'.
Fixes: 480
Moderator's note:
Thread moved from My Router to My Order
Dushyantor
I won't be able to say if it's fixed it until I return to my property in September. The post is pretty clear if you read it!
Fixes: 389
And as I said, it SHOULD just work when you switch routers - if you have a problem on you return, post back.
Dushyantor
Will do. I was just worried about any sort of deadline etc. I'll give it a go as soon as I can. Thanks
markhawkin
Champion
Fixes: 22
If you have the router I would expect the switch to complete within days.
Unless there is an upgrade to full fibre involved it's a reprogramming in Openreach's systems and could be invisible to you.
If you leave the EE router plugged in, if you are away, phoning your landline number would be a reasonable test. After a few rings it would go to the Digital Voice answering machine.
