Cutting it fine? :(
- My Order
- Cutting it fine? :(
Cutting it fine? :(
03-09-2020 2:38 AM - edited 03-09-2020 2:40 AM
Date: Wed, August 19, 2020 2:31 pm - Your new Home Phone service should be available on 3/9/2020.
Date: Wed, September 2, 2020 3:23 pm - Your router's on its way!
Previously - Shell, NowTV, Sky, EE, New Call Telecom/Fuelbroadband, Plusnet, Virgin/NTL/Bell Cable, Crosswinds, IC24, FreeOnlineNet, X-Stream, Totalise, Freeserve, Force9, TescoNet, AOL, Freenetname, Pipex, E7
Re: Cutting it fine? :(
04-09-2020 1:50 PM
Indeed they are . I just called them up is when the order was placed for the modem. I switched on 25 aug and its 4th sept now. go live on 9th sept so yea.. unless you chase up... no responses
04-09-2020 2:48 PM
Mine arrived half an hour AFTER my phone line was activated.
Perhaps I should give up expecting a reasonable service from them?
TBF they are the 2nd best out of all my recent attempts to get a reasonable broadband supplier. That doesn't say much for the rest, but there are still some that do try and help.
08-09-2020 12:01 AM
08-09-2020 4:04 AM - edited 08-09-2020 4:12 AM
Eh?
I'm confused: how would I get "a tracking reference", if there "is no tracking"?
Still; I got my rewards claim. Odd that it says "this short form" so I filled that out, then it says "click here" which just says "You've already successfully claimed your reward"?
08-09-2020 8:44 AM
well that's encouraging! lets see what happens tomorrow. cheers
08-09-2020 9:18 AM
Tomorrow? I think the email said about 30 days.
08-09-2020 9:31 AM
08-09-2020 9:43 AM
Good luck with that. The service once you get on it is good, but you may need to chase them to activate your broadband. I've had to do that the last three or four times I have been with them.
08-09-2020 3:57 PM
08-09-2020 4:16 PM
That's good.
They may just be short of staff or something atm, as I don't remember this problem in the past.
