Checked the status of my order and it just says strCustActivationDate
Christine5
I ordered my broadband around 2 weeks ago and have received the router but when I check for a activation date it just says strCustActivationDate. I'm quite sad to see how poor the communication has been regarding my order and I hope the quality of the broadband makes up for it.
9 REPLIES 9
Fixes: 1,641
Re: Checked the status of my order and it just says strCustActivationDate
Thanks for your post @Christine5 and welcome to our Community Forums.
I'm sorry to see your activation date isn't showing up in your account.
I can though see we've emailed you on the 30th October to confirm this is tomorrow.
Christine5
Okay so I still haven't received a confirmation that my broadband will he activated today. My old broadband has been turned off so now I'm without internet. If you could help me with this I would be very grateful.
Fixes: 1,641
Thanks for getting back to me @Christine5
I've just had a look into this for you and the order with suppliers to activate our services is still in progress for today.
It can take anytime up to midnight but usually quicker. Really sorry for the downtime, there's a lot of work that goes on behind the scenes when you move to another provider and there's generally some gap in service on the day.
Feel free to let me know if there are any further issues though.
Christine5
I know you said up to midnight but I've seen other people having the same issue as me and they called up CS and within 10 minutes the broadband was activated . Just wondering if this was a good idea.
Fixes: 1,641
That'll generally only work if the order's completed with our suppliers but your account's not yet activated.
Checking again I can see that is now the case so I've just activated things for you now.
Let me know how it goes once you've setup your router Smiley
Christine5
Hello again, the Internet seems to be stable and working fine however the speed is quite a bit under the minimum. Its around 30mbps and the minimum is 40mbps. I've had the same problem with my previous provide and that's why I switched because I thought the speed would improve.
After seeing that it's still around the same speed I can only assume that their is a problem my line. I've tried all the sockets in the house and the speed stays the same with everyone.
I'm hoping the cause of this problem can be found and fixed.
LaurenB
Fixes: 131
Hiya @Christine5, I am really sorry that you are having some issues with the service so soon.
I have tested your line today and this has detected a fault in the network, likely causing the issues you're seeing. I have now raised this to our suppliers for you and we'll need to look at sending you an engineer.
I have created a fault ticket here: https://www.plus.net/wizard/?p=view_question&id=219630481 with the next steps in getting this progressed.
If you can please reply on the ticket with the requested information (and let us know on here once done) we can get that progressed for you.
 Lauren Barry
Christine5
I have just replied to the ticket confirming the speeds are still the same and gave information on when I'm available for an engineer to come around.v
Fixes: 1,641
Hi @Christine5
I can see we've booked the engineer visit and updated your ticket 219630481 with the appointment details.
Let us know how it goes Smiley
