Can I change the delivery address for the router
Lockersv
Am I able to amend the delivery address for my router to my current address? As there won’t be anyone at my new address the few days before to accept the delivery.
12 REPLIES 12
Fixes: 334
Re: Can I change the delivery address for the router
@Lockersv Yes you can amend the delivery address - just call Customer Support. When are you expecting it?
mystreet1
Fixes: 4
As @jab1 stated, you can get it redirected, but it should fit in a standard size letterbox.
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Lockersv
Thank you! Not for a couple of weeks so should be ok to amend hopefully!
ricopuertojireh
Hello there. Is there any update on your delivery address change? I have the same concern that delivery will arrive at my new address before we transfer and no one will receive the package.
Please keep updated; it will be extremely helpful.
Fixes: 334
@ricopuertojireh If you wish to arrange a redirection for your router delivery, you need to contact contact Plusnet Support personally.
Fixes: 87
@ricopuertojireh
I don't know the actual size but the Router will fit though a standard letter box with no signature required.
ricopuertojireh
Do i need to call them asap, or wait for an email update regarding my order and order status as mentioned in the email i received?
ricopuertojireh
my concern is maybe it will arrive earlier than expected. I still dont have the key of the house, I cant confirm if its inside, or safe or what so ever.. I just have that thought in my mind. Cheesy
thanks...
Fixes: 334
When are you due to move, @ricopuertojireh ? If you don't have a confirmed installation date, you may find you have moved before the installation is confirmed. Which service have you ordered?
The hubs are despatched RM24 Tracked to arrive 2/3 days prior to a confirmed installation.
ricopuertojireh
end of the month. I put the same date of our transfer and date of activation Cheesy (i think its a bad idea :D)
if they can deliver it the same day, then its fine.. but if they send it like a week before, then no one will be there.. Cheesy
Fixes: 334
Which service are you taking? As  I said, the Hubs are despatched to arrive 2/3 days before a confirmed installation/activation date.
ricopuertojireh
then i think it will be fine if 2 days before.. if indeed it will fit in standard letter box.. Cheesy  thank you for that. ill check the delivery status to keep me updated.. will post here what happen Cheesy
