Can I change the delivery address for the router
- My Order
- Can I change the delivery address for the router
01-11-2025 8:24 PM
Am I able to amend the delivery address for my router to my current address? As there won’t be anyone at my new address the few days before to accept the delivery.
Re: Can I change the delivery address for the router
01-11-2025 8:29 PM
@Lockersv Yes you can amend the delivery address - just call Customer Support. When are you expecting it?
02-11-2025 4:08 PM
03-11-2025 12:45 PM
05-11-2025 11:59 AM - edited 05-11-2025 12:06 PM
Hello there. Is there any update on your delivery address change? I have the same concern that delivery will arrive at my new address before we transfer and no one will receive the package.
Please keep updated; it will be extremely helpful.
05-11-2025 12:09 PM
@ricopuertojireh If you wish to arrange a redirection for your router delivery, you need to contact contact Plusnet Support personally.
05-11-2025 12:11 PM
I don't know the actual size but the Router will fit though a standard letter box with no signature required.
05-11-2025 12:17 PM
Do i need to call them asap, or wait for an email update regarding my order and order status as mentioned in the email i received?
05-11-2025 12:19 PM
my concern is maybe it will arrive earlier than expected. I still dont have the key of the house, I cant confirm if its inside, or safe or what so ever.. I just have that thought in my mind. ![]()
thanks...
05-11-2025 12:21 PM - edited 05-11-2025 12:24 PM
When are you due to move, @ricopuertojireh ? If you don't have a confirmed installation date, you may find you have moved before the installation is confirmed. Which service have you ordered?
The hubs are despatched RM24 Tracked to arrive 2/3 days prior to a confirmed installation.
05-11-2025 12:30 PM - edited 05-11-2025 12:31 PM
end of the month. I put the same date of our transfer and date of activation
(i think its a bad idea :D)
if they can deliver it the same day, then its fine.. but if they send it like a week before, then no one will be there..
05-11-2025 12:42 PM
Which service are you taking? As I said, the Hubs are despatched to arrive 2/3 days before a confirmed installation/activation date.
05-11-2025 12:47 PM
then i think it will be fine if 2 days before.. if indeed it will fit in standard letter box..
thank you for that. ill check the delivery status to keep me updated.. will post here what happen
- My Order
