Broadband still not activated
rebeccahomer
My broadband should have been live by midnight 31st December, Openreach engineer came out yesterday at 8.30am and he said it was all ok his end. Nothing has happened since. I called plusnet who advised that it should be up and running and not sure why it’s not. Couldn’t put me through to the team that deal with this as they are out of the office until Tuesday!!! Whist I think everyone deserves a break over the holidays why schedule new customers to be activated over bank holidays if no one is there to sort out any issues!! I have raised a complaint today at midday and promised a call back within 2 hours…no one called so I called them but they were closed. I think this is really really poor and not a great new customer service experience
23 REPLIES 23
Fixes: 334
Re: Broadband still not activated
@rebeccahomer Welcome to the Community. When you say your broadband is still not activated, what do you actually mean? Presumably your Hub is plugged in and switched on - which one is it? What colour are the lights?
rebeccahomer
The open reach engineer came and he plugged it in. The light is solid orange and I haven’t had an activation text / emails which to say it’s active. Thanks
Fixes: 334
OK. Sometimes the texts/emails don't come through, but it does sound a little like something has not quite completed at the Plusnet end.
You haven't said which Hub it is, but is it possible to log into the Hub and check the username and password showing on there?
rebeccahomer
Thanks John, it’s a hub two. When I log into my plusnet account is says order in progress
Fixes: 334
OK Rebecca. If you log into the Hub, what details does it show for you 'username' - this sounds a bit like the automated system hasn't completed your activation correctly.
rebeccahomer
Sorry to sound stupid but how do I do that?
Fixes: 334
Doesn't sound stupid, not everyone knows. Open a new tab in your browser, type in '192.168.1.254' - without the quote marks - and then fill in the 'User' and 'Password' details exactly as the details on the card supplied.
Fixes: 236
Steady Orange light suggests that the router is in sync with the cabinet.  It is not however connecting to the PlusNET internet service.  See https://www.plus.net/help/broadband/router-setup-guides/hub-two/
There have been cases where there is a wrong connection in the cabinet and the line is not connected to the right number.  It would be worth dialling 17070 check that the line identifier is correct and that the line is quiet (option 2).
The router should auto configure if on the right line and the service has been activated.  John is leading you to manual configuration of the user name.  If the line is not active that is still not going to work and will require staff intervention.  Normally all of this works with zero intervention.
Fixes: 334
@Townman Yep, I was going that direction, and I did forget the possibility of a cabinet connection issue - thanks for the nudge. I was going to suggest, if this proved difficult that @rebeccahomer waited for the Help Team to pick up, but just wondered if I could get there first. 😉
Fixes: 236
It's a good approach which will eliminate all within the user's ability to check out.
rebeccahomer
The browser doesn’t respond when I put in those numbers
rebeccahomer
Really helpful, thank you. I clicked on trouble shoot and it had the wrong landline number in so clearly something wrong with the line.
Fixes: 334
Strange, Rebecca - where are you entering them? In the address bar or a search bar? It should be in the address bar.
Fixes: 334
OK. This will need PN Help Team intervention. Hopefully one of them will pick it up tomorrow or more likely Monday.
Sorry for the hassle.
