Broadband product change schedule didn't happen
Estat
My ticket stated that my
 Product change from Plusnet unlimited to unlimited fibre "Will take place on 2018-02-28 02:00:00
I expected that it would happen then or during that day.  Am I expecting too much ?   Is this just a start point or is there a problem in that it's not happened?
5 REPLIES 5
Fixes: 418
Re: Broadband product change schedule didn't happen
Have you tried rebooting your router to see if that does anything?
Estat
On oŕdering was informed that I would be emailed when switched over also may notice that service wasn't working, then I  could swap the router.  They say not to try to use new router until change carried out.
Browni
Aspiring Hero
Fixes: 60
Pop you number into the DSL Checker and have a look at the narrative below the estimates.
It should say something like "an open order is due to complete on..." and give the date when the work should complete.
Note that it can take up until midnight of that date for the work to be done.
Fixes: 418
So changing from ADSL to fibre needs a router change (probably true) that has to be held back until the change is completed (why?). Is it me or do some agents need some training.
For information, the Plusnet Hub One works on both ADSL and VDSL.
Fixes: 1,600
Welcome to the community forums @Estat
As you've already discovered our suppliers have delayed your upgrade due to engineer availability in your area. Apologies for the lack of communication and for any inconvenience caused.
Your new router will work with both ADSL and Fibre. If you set it up beforehand then once the work is carried out on the day you should experience just up to a few hours drop in your connection and when it returns you should be on fibre.
