Broadband order stuck on Checking your line
gouttegd
I recently moved in my current flat and last week I subscribed for a broadband service from Plus.net.
When tracking my order, I see that it appears stuck at the step "Checking your line" ("We've found a potential problem on your telephone line. We'll look into this and will be in contact with you shortly."). I have first seen that this Monday and nothing has changed since. I have not been contacted by Plus.net.
Can I have any more details on what is going on and what is this "potential problem"?
(For what it's worth, according to the landlord the previous tenant was already a Plus.net customer, so I did not expect any kind of trouble that may occur when switching from one ISP to another.)
Regards,
4 REPLIES 4
Fixes: 1,600
Re: Broadband order stuck on Checking your line
Hi there.
I'm taking a look into this for you now. Smiley
Fixes: 1,600
Thanks for waiting and I'm sorry for the lack of communication.
It looks like our automated system failed to place the order with Openreach, because it detected the telephone number provided to us was already in use on another account. Likely the previous tenants.
As I can see that that account is closed/services ceased, I've manually placed the order now. Normally in these instances we should be able to get your services up and running without an engineer visit.
But it doesn't look like there's a "stopped line" showing we can restart so I've had to place an order to install a new line. Once the order is confirmed by Openreach we should be able to request that the engineer just activates the services externally.
When we have more info we'll be in touch via this ticket: https://www.plus.net/wizard/?p=view_question&id=160578662
I hope this helps.
gouttegd
Thank you for your quick reply and your help! That's very much appreciated.
Fixes: 1,600
No problems at all, fingers crossed it doesn't take long for the engineering work to take place.
