Broadband order not activated on date
- My Order
- Broadband order not activated on date
17-06-2022 11:21 AM
I'm switching to Plusnet from another provider (standard ADSL broadband), the activation date was supposed to be yesterday but still it's still not completed. I haven't had any contact saying the order was delayed, can someone shed some light on this? Thanks.
Re: Broadband order not activated on date
20-06-2022 11:00 AM
Is there any update on this?
20-06-2022 12:46 PM
I'm really sorry for the delay. Does your broadband with your previous provider currently still work okay?
From what I can see our order to transfer your service across to us is delayed in the supplier systems, because what's known as a "stop order" wasn't passed across to your current provider as a notification for the transfer.
Depending on whether you have broadband still would depend how we tackle this.
If your broadband does work, then I can raise a case to our supplier systems support desk to investigate further, however if it doesn't work, then I'd be more inclined to ask our suppliers to cancel the order and then replace it.
20-06-2022 1:28 PM
Hi thanks for the reply.
My broadband with the previous provider doesn't work anymore.
Would I be able to get a rough idea how long it will take to resolve (assuming the order will be replaced as mentioned in your reply)?
I'm needing it for my work. Thanks
20-06-2022 2:03 PM
Assuming that the line is no longer active with your previous provider which likely isn't going to be, if your broadband doesn't work, then I'll be requesting the new order's expedited to completion.
As a rough timescale, I would say within 5 working days from when I'm able to place the order.
I've got in touch with our suppliers helpdesk and they're in the process of cancelling the existing order, which should be done by tomorrow, so I should know more then. Will let you know once I do.
I'll keep a close eye on this for you and make to get you back up and running as soon as possible for your work.
21-06-2022 12:07 PM
The order's cancelled, but the supplier records are showing the line in both a working and non-working state at your address, which is stopping me from replacing the order. I've been chasing this up with our suppliers through a case to their systems support desk and I'll update you again later today. Really sorry for the delay.
21-06-2022 12:17 PM
Ok thanks for the update
21-06-2022 12:34 PM
No problem, I've spoken with the supplier helpdesk just now and they're passing the case to their second line support team. I should have an update within 24 to 48 hours and will let you know as soon as I do.
22-06-2022 4:36 PM - edited 22-06-2022 4:41 PM
Heya, just to update I've been escalating this with our suppliers and they're definitely on the case. It seems to be a rather complex issue and sorry I haven't got more of an update yet. Should hopefully know more tomorrow.
[edit]
In the meantime, is it possible for you to call your previous provider just to confirm if the service is ceased their side and if it isn't then to test the line and try to raise a fault to get you back online?
22-06-2022 10:39 PM
" supplier records are showing the line in both a working and non-working state"
Schroedinger line stats?
24-06-2022 11:11 PM
I think someone appreciated my s-o-h.
27-06-2022 12:33 PM
Just to confirm I've checked and the service is definitely ceased on their side.
27-06-2022 12:51 PM
Thanks for checking!
Do you use a landline phone by any chance or know if that's ceased as well as your broadband?
I've also chased this up with our suppliers this morning and one of their managers is looking into this.
27-06-2022 12:55 PM
Hi, sorry I don't use a landline phone so not sure on that.
27-06-2022 12:58 PM
No problem, if your previous provider have confirmed it's ceased their side I'll take it to our suppliers to investigate further.
I'll let you know once I know more which should be today or tomorrow at the latest. Sorry that this is dragging on.
- My Order
