Broadband activation
FIXED- Subscribe to RSS Feed
- My Order
- Broadband activation
21-09-2020 10:41 PM
I have recently made a new account and have made my first broadband payment via direct debit which i had set up over the phone however my broadband is not yet active, i was wondering roughly how long this broadband activation would take or if it could be done manually as we use internet quite a lot in my household.
Thank you in advance for taking the time to read this post
Fixed! Go to the fix.
Re: Broadband activation
21-09-2020 11:22 PM
This topic has been moved from Fibre Broadband to My Orders.
Customer and Forum Moderator. Windows 10 Firefox 103.0.2 (64-bit (64-bit)
Delayed broadband
22-09-2020 12:31 PM
I recently made a post, which seemingly got ignored. So I'm making this post to hopefully get a response this time.
I recently paid for fibre broadband and it says on my account that my order is still being processed, however I've seen many other posts on the forums with similar issues and it has taken over a month in some cases for people to get their wifi back. When setting up my account over the phone and making my first payment for broadband, I had 4 different people tell me varying lengths of time of which my internet would be activated. None of them gave me an actual date of activation, which I've seen is supposed to happen and I haven't received any confirmation via email or text regarding when my broadband is likely to be active.
At this point unless I get an activation date soon I will be leaving, because moving to another ISP would only take 2 weeks whereas this could take well over a month as I was informed by 1 of your staff members.
Thankyou,
Laura.
Re: Delayed broadband
22-09-2020 2:02 PM
Moderators Note
Topics on same subject merged.
25-09-2020 4:04 PM
Thanks for getting in touch @Laurapalmer
I'm sorry for the delay with your order. I tried to call you today on your mobile but there was no answer. Unfortunately due to a system issue we weren't able to automatically place your order but I've put that through manually now.
I'm firstly reactivating the stopped phone line at your address which was ceased by the previous provider on the 21/09/20. Once that activates on 28/09/20 I'll place your fibre order and call you back to advise when that'll go live.
I'd expect the fibre order to take 5 working days so if all goes to plan you should have a broadband service by 05/10/20 however this may be delayed depending on engineer availability to carry out external work at the cabinet.
I'm taking this on personally moving forward and I'll follow up on Monday.
[edit]
Having read your post again if we closed your previous account it's likely we ceased the line on 21/09/20. With any luck when the phone's active we should hopefully be able to get your fibre back on a lot sooner if the all equipment is in place at the cabinet still (The cabinet is the green box in the road)
25-09-2020 6:18 PM
Thankyou for getting back to me about this, I had a feeling the order didn't go through.
I appreciate you taking it on personally and I look forward to hearing from you on Monday.
Laura.
06-10-2020 11:12 PM
My broadband order is supposed to be complete however so i'm confused as to why my internet is not active.
07-10-2020 1:54 PM
Hi @Laurapalmer I tried to call you today on your mobile to follow things up with you but there was no answer. I can see you've spoken with our support team and you've reconfigured your existing router to work with your new account.
Let me know if there are further issues or anything else you'd need help with.
08-10-2020 11:01 AM
Go to the plusnet hub manager (you can google what to type in to get there). Make sure your username and password on there is the exact same as the one you used to sign up to plusnet with. If not you'll need to go into the advanced settings to change it and it should work for you too.
08-10-2020 11:27 AM
Thanks for the post back @Laurapalmer
No problem, let us know if you need any further help.
