Broadband activation date "{strCustActivationDate}"
FIXEDTopic Options
- My Order
- Re: Broadband activation date "{strCustActivationD...
14-02-2020 7:04 PM
Hi there
I have just had my phone line connected and activated earlier today, I just attempted to check when the fiber would be up and running though the order tracker but it doesn't have a date just "{strCustActivationDate}".
Is there an issue with my order or just a bug on the website? Either way knowing when the fiber is due to be activated would be very helpful.
Thanks.
Thanks.
Fixed! Go to the fix.
Message 1 of 4
(923 Views)
3 REPLIES 3
17-02-2020 7:59 PM
Hi @devinmorrison, thanks for getting in touch.
It looks like your service is active and working on your side. Can you confirm all is well from your side?
Regards
Message 2 of 4
(853 Views)
Re: Broadband activation date "{strCustActivationDate}"
17-02-2020 8:03 PM
Ahh sorry I had completely forgotten I posted here, yes all is fine got activated the same day as my phone thank you. Sorry if I caused you any extra work.
Message 3 of 4
(850 Views)
17-02-2020 8:16 PM
Message 4 of 4
(841 Views)
- My Order
