Broadband Switch to plusnet
markusjbarr
Hi, I switched to Plusnet last week, Router arrived on Tuesday, all installed on Wednesday, and has been working fine so far.
What do I do about my previous connection?
When I signed up, I used the broadband switch service, so Plusnet notified my previous supplier that I would be leaving.  I've received emails from both confirming this would happen on my "go live" day with Plusnet.
I didn't receive any email about it yesterday.  Do I need to contact them separately to cancel? (I'm out of the contract window and on a rolling deal so shouldn't be an issue)
Thanks Smiley
8 REPLIES 8
Fixes: 387
Re: Broadband Switch to plusnet
@markusjbarr I don't think you need to 'do' anything. Under the OTS switching rules, everything is coordinated between the two providers.
What exactly is your  concern?
markusjbarr
Thanks Jab1.
My concern is that my previous service isn't cancelled/stopped and i end up paying for 2 services for longer than i should be
Fixes: 585
@markusjbarr as long as you received communication from your old supplier acknowledging that you were leaving, then you should get a final bill from them within 21 days.
Who was your old supplier ?
markusjbarr
Thanks MisterW, it is virgin media
Fixes: 585
@markusjbarr Ah! . In the past , one has had to cancel directly with VM since they use completely separate infrastructure. The new OTS system is supposed to fix that so that a move from/to any supplier is handled automatically. Given that you've received the 'sorry you are leaving' , it looks like that is how it should be. However, we have seen occasions where VM dont cancel correctly from the OTS notification.
I might be inclined to check that they have processed the migration notification from the OTS system correctly. Don't take any rubbish from them that they've not receieved notification from Plusnet, the notification comes from the OTS system NOT Plusnet
Fixes: 387
You beat me to it, @MisterW .
markusjbarr
awesome, thank you! Smiley
LexLex2020
Fixes: 12
The One Touch Switch was set up in this instance @markusjbarr.
So you shouldn't need to contact virgin to close the account or anything!
Lex Keehner
