Booking a ONT Shift
jbrssl
Booking a ONT Shift
Hi, I recently upgraded to fibre but the engineer installed the ONT in my ground floor room (front of house), while my previous point of input was a room upstairs (also front of house).
I was told by the OR engineer I'd have to contact Plusnet to arrange for a visit to shift the ONT.  I'm aware there's going to be a cost involved.
How do I start this process?
5 REPLIES 5
Fixes: 1,495
Re: Booking a ONT Shift
Moderators Note
This topic has been moved from Full Fibre to My Order
markhawkin
Champion
Fixes: 22
I can't comment on booking an ONT shift, but you could also consider having a network cable run between the ONT and where you want your router.
Electricians have often "upskilled" to run and terminate network cables.
mystreet1
Seasoned Pro
Fixes: 7
It may be easier and cheaper to run some network cable to your preferred location.
This kit on Ebay will give you everything that you need
https://www.ebay.co.uk/itm/301746931598?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=Re5hHE0-Rpq&s...
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Fixes: 117
@jbrssl
Consider getting someone in to run an external ethernet cable to your desired location. Probably as cheap as getting the ONT moved and is future proof.
jbrssl
Thanks all for the advice.  "Getting someone in" is my only option, but installing an ethernet cable externally instead of moving the box make a lot of sense.  I'll look around for a local engineer/electrician.
