Awful Customer Service
FP1878
Hi all, so on the 7th I laid PN 75 quid to have my broadband up and running today as I need it to work from home. No sooner had the money been taken did they cancel my engineer visit. Since then I can’t get through on the phone, they ignore all my messages and tweets and basically I have no idea what’s going on. I’m regretting using PN right now as the customer service is atrocious. Any advice? Thank you
Tags (1)
3 REPLIES 3
Fixes: 1,474
Re: Awful Customer Service
Moderators Note
This topic has been moved from Fibre to My Order
pdm
Have you raised a complaint via the Help Assistant?
Took a while but I have now had some response.
Worth at try.
jgb
Champion
Fixes: 21
@FP1878
As well as the route that @pdm suggests, have you tried ringing the Customer Options Team who are basically the sales side that you would ring to set up a contract? Their number is usually less busy and hopefully they can give you some info - the number is 0800 013 2632.
Also, have you checked via the Help assistant on the Members Centre > Manage Account if there are any tickets (often closed ones) that may shed some light?
