£49.99 installation fee when switching from BT to Plusnet?
Firefly
I'm considering switching from BT to Plusnet when my current BT Broadband contract expires in less than 2 months. However, when signing up to Plusnet, it tells me there is a £49.99 installation fee and I need to book an engineer! But I think Plusnet uses the same network, so if I have a working BT Broadband connection, why would I need an engineer?
Can I avoid this this fee and engineer visit? Just plug in the hub myself?
6 REPLIES 6
Fixes: 245
Re: £49.99 installation fee when switching from BT to Plusnet?
What’s your BT service and what service have you ordered from Plusnet.
A reasonable guess would be that this is a migration from copper ADSL / FTTC / SoGEA to FTTP on a fibre priority exchange (or you want higher speeds than the current service).  A switch to FTTP requires an engineer.
If you are on FTTP already, then something is a tad odd.
Fixes: 382
@Firefly What connection are you on with BT, and which service are you intending to get with Plusnet? I think you are quite correct though - the PN  service is delivered over exactly the same infrastructure as BT, and it is, apart from some external 'button pushing' as you describe - when you are told the switch is complete, you plug the PN Hub in place of the BT one.
I thought the 'connection charge' no longer applied?
Firefly
It's been solved! (somehow)
On the Plusnet website, I enter my address, then I get presented with a deal. Then when I went to checkout it told me about the engineer and installation fee.
But I just repeated these steps again and now it tells me explicitely that I don't need an engineer! So, apparently I did something wrong (?). But the problem is solved now. I can just register and set an activation date.
Thanks for your help guys!
Btw: with BT I have partly fibre. The last 50 metres or so is copper.
Fixes: 245
What product have you ordered from Plusnet?
Firefly
That will be just broadband. I haven't completed the order yet, because it turns out I cannot put the date far enough into the future. My BT contract ends 27 Dec and I don't want to pay the termination charges. So I will continue with the order mid Dec.
Fixes: 117
@Firefly
Just to confirm - you are aware the move will cost you your landline if this matters?
