spurious charges for 1471
- My Account/Billing
- Re: spurious charges for 1471
25-05-2017 1:24 PM
new to this and plusnet so heregoes
I got two charges of 20p and customer services said it was because I rang back using call back option.
they wanted to send an engineer for £65 which would be payable if my line was ok!
I used 1471 but only to see if anyone rang, i got a number was hidden number message.
I did not press to ring back twice as plusnets infallible equipment showed and charged for!
I am the only person living here and my pet cat is passed on.
anyone else had this problem?
25-05-2017 3:10 PM - edited 25-05-2017 11:02 PM
If you had phone with caller id (CLID) you'd have no need to ring 1471; if 1471 offered to ring the number
that called, don't use unless in your call options. If no number was generated, can't see why PN would charge.
The separate issue of OPENREACH's charge applies, if you have a fault and it's determined
fault is not between exchange and your master socket, but with your internal wiring/ accessories eg phones\filters\splitter sockets.
26-05-2017 1:04 PM
Welcome to the community forums @steve17
This does sound quite strange, however it does appear that the feature was used on your line. Looking at the notes on your account, I understand you've agreed to keep an eye on this and let us know if you notice any other suspicious activity.
06-06-2017 11:49 PM
Hi, I thought to check the rest of my bill, no calls made lasting any length at all.
If the calls were made at any time they would show on my bill! Surely?
I do NOT click to CONNECT any option to Auto Dial via "the operator" I'll dial it myself. IT IS CHEAPER.
Its only 40p but it is the principal of the thing! I do not steal (take money that isn 't mine or falsely claimed) I think PN hould stand up to BIG brother.
07-06-2017 11:33 AM
Looking at your account, there are calls showing on the itemised phone bill.
You can view your itemised phone bill here: https://www.plus.net/plustalk/index.php?page=wlr_itemised_billing&view_bill_date=
This initially shows a break down of the type of call and total numbers of calls/duration, however clicking view details will show a break down of each call.
