referal wrong
- My Account/Billing
- referal wrong
referal wrong
24-04-2015 7:52 AM
hi have a recent referral showing as 75p should be £1.25 can somebody kick the calculator please
Message 1 of 4
(851 Views)
3 REPLIES 3
Re: referal wrong
24-04-2015 8:15 AM
Is the referrals product "Business Fibre Unlimited"? That is the only one showing with a referral value of £1.25.
If it isn't I'm guessing that you may be adding 75p from their broadband to 50p from their phone to get the £1.25?
If that is the case then the 2 referral values show as 2 separate lines in the list of referrals.
If it is the value at the top of that page that is showing the amount of credit you currently have, then the amounts are only added to that when they have been billed (or maybe payment taken, I forget) from the other user. If they are a new referral then it is likely that phone and broadband haven't gone live at the same time.
I hope that helps
Phil
I hope that helps
Phil
Message 2 of 4
(332 Views)
Re: referal wrong
24-04-2015 8:26 AM
i had one where the bb for 75p was there two weeks before the 50p for phone line, so as Phil says it's probably a timing issue.
Message 3 of 4
(332 Views)
Re: referal wrong
24-04-2015 12:54 PM
thanks for reply, yes phone &broadband went live same day both showing status active, values are both there but total tokens showing 1&0 total credit 75p&0
Message 4 of 4
(332 Views)
