"http://failed.billing.plus.net/apps/payment/failed" Issue
leetwin88
Re: "http://failed.billing.plus.net/apps/payment/failed" Issue
hi im getting the same issues since last friday when i connect to a vpn everything works soon as i disconnect boom back to square one ive phoned a few times now and keep getting past about i am thinking of canceling with plus net and going else where as it seems nothing is being done
OskarPapa
Fixes: 65
Hi @leetwin88, thanks for the update.
We can see that your connection has been intermittent (to say the very least) today.
Now that it's back up and running is the issue resolved, or is it still ongoing?
leetwin88
no it is still ongoing only way i got full access is when using a vpn i was told to turn router off for 65mins but still no luck these as been going on for nearly 7days now and been told to do the same thing all the time ive also tried 2 different routers and still no luck like i said only works with vpn
OskarPapa
Fixes: 65
Hi @leetwin88, thanks for the update and for your private message.
As the social media team are unsure as to why this is happening (especially with the issue affecting all of your clients), we've emailed the relevant networks department for further support on this issue.
We'd expect to receive an update at some point today at which point, we'll update this thread for you.
If you need any further assistance in the meantime please don't hesitate to get back in touch.
leetwin88
Hopefully will be sorted as been waiting 7days for this to be sorted.
MatthewWheeler
Fixes: 479
Apologies for the continued inconvenience.
As soon as we know more we'll update you further
 Matthew Wheeler
Ensor
@MasterOfReality wrote:
Hi @Ensor
Really sorry for the issues which you have had.
No problem, these things happen.
Sorry for coming over so shirty. I'm currently going through hell due to having had my anxiety medication changed recently, patience lives on another planet from my point of view right now! Crazy2
leetwin88
You never guess what it's happened again this month soon as my bill gets paid I get this error been like this since the 17/12/2018 I know I'm still in contract but I am in the process of moving suppliers this shouldn't be happening two months in a row.
Cazlizzy
this just seems to be an ongoing problem for so many. The guys here sorted this for me about a week ago..but now its happening again..I tried to get to my account today to pay my bill and it fails every time. Hoping like you that someone sorts it again for me. Sad
Mads
Fixes: 79
Hello @leetwin88, I've reconfigured a few things on our side that should now allow you to use your services within the next hour.
@Cazlizzy, I am very sorry to hear you have been restricted early, I have now removed these restrictions for you. You should be able to browse normally within the hour.
If either of you have any further issues or this does not help please get back to us so we can investigate further.
leetwin88
Ok thanks will check and get back. Thanks.
leetwin88
Nope that didn't work either only way I can browse online and watch Netflix and play online is via VPN access this needs sorting nearly two weeks and no solution.
Fixes: 1,600
Sorry to hear you're still having issues.
I've made a different change to your account, can you let us know if you still can't browse after 5 minutes please?
leetwin88
No stick getting this picture attached
Fixes: 1,600
Thanks for the picture.
Are you able to replicate this across a wired connection?
