"Failed" fibre upgrade request (due 8th)
PeeGee
On 5th June, I decided to accept an "offer" to move from fibre to fibre extra and save 99p per month and duly received a confirmation e-mail (Ref: EPN0099) with a change date of 8th June.
One minute later a second e-mail (REF: E0553) arrived indicating there was a problem. Checking the tickets, Ref: #202415355 states:
A modify order on this account was unsuccessful.
The reason given was "Self install is not a modifiable parameter.".
Modify order type:
An attempted move from ADSL 1 on WBC to ADSL2+An attempt to change the upstream capping
Request assistance to sort this problem.
Phil
Plusnet FTTC (Sep 2014), Essentials (Feb 2013); ADSL (Apr 2009); Customer since Jan 2004 (on 28kb dial-up)
2 REPLIES 2
RealAleMadrid
Aspiring Hero
Fixes: 51
Re: "Failed" fibre upgrade request (due 8th)
@PeeGee  This seems to be happening quite often. Have a look at this thread, you will need PlusNet staff to sort it.
https://community.plus.net/t5/My-Order/Upgrade-from-Unlimited-Fibre-to-Unlimited-Fibre-Extra-quot/m-...
PeeGee
Thanks, will look there, though expected it would need staff intervention.
