mac code
trufflesdad
mac code
If I take out a contract with bt complete with line installation will I need my mac number from Plusnet?
10 REPLIES 10
Oldjim
Resting Legend
Fixes: 63
Re: mac code
why would you want to do that
ordering a second line and then cancelling the Plusnet line will land you with the cease charge
I have moved this to Accounts and Billing
MattyC
Fixes: 46
Re: mac code
If by line installation you mean a second line installing, then no.
If you are looking to migrate away, but keep the same line, then it's a yes.
trufflesdad
Re: mac code
I believe I have a line fault but the engineer callout fee is beyond my means so thought if I opened
a BT account and got a new line It would ensure the fault was cleared..
dick:quote
hillyfields123
Re: mac code
Surely if it's a fault with the line then there's no charge to pay?
trufflesdad
Re: mac code
Correct but although I have tested all I can including trying new routers and wiping and reinstalling
operating system there might be something I have missed.I have tried the plusnet b/band checker
but as yet had no useful results back. Might get a local telecom engineer to call and change the socket
and check the system cost of £25 is better than the the bt charge..
adie:quote
trufflesdad
Re: mac code
Quote from: Oldjim
What charges will I incur if I change my provider ?
plusnettony
Plusnet Staff
Plusnet Staff
Fixes: 18
Re: mac code
This depends on your contract so it's not really something I can answer here.
When you contact our customer option team, they will be able to advise on these matters.
 Tony T
PeterLoftus
Fixes: 5
Re: mac code
@trufflesdad am I missing something?
The first thing to do is raise a fault  Huh
Do you have a ticket number?
To do is to be - Neitzsche
To be is to do - Kant
do be do be do - Sinatra
trufflesdad
Re: mac code
I filled in the broadband fault finder last week but no helpful replies .
dick:quote
hillyfields123
Re: mac code
Quote from: trufflesdad
If you're talking about the master socket (NTE5) then this is illegal because this isn't your property. ONLY Openreach are allowed to do anything to the master socket (excluding the faceplate if you have one)
If you post more about the suspected line fault and it's symptoms then other members on this forum or PN staff might be able to help diagnose the issue.
