line rental saver
login
line rental saver
Although I have been trying for two weeks on and off I cannot purchase the line rental saver.
The system tells me nor can the customer service people renew on my behalf.
Are you in a position to inform me when the online option will be available.
15 REPLIES 15
Satss
Fixes: 37
Re: line rental saver
Hi @login,
Sorry to hear about this issue. I have responded via a ticket on your account here
Kind regards,
login
Satts. Have replied to your ticket on this issue. If it does not get through please let me know
MasterOfReality
Fixes: 57
Hi @login
I've taken a look into this again and updated the same ticket @Satss left on your account.
You can use her link to get back to this.
Thanks,
MoR
login
MoR
Thanks for getting back to me. Will try to purchase LRS on 27th as advised,
Will keep you updated
Thanks Login
EmilyD
Fixes: 117
Thanks @login,
Please let us know if you experience any problems with this and let us know if there's anything else that you'd like to discuss in the meantime.
 Emily D
login
Hi EmilyD
I would like to take up you offerr to discuss anything while we wait for 27th.
I still have not received any response to my question 18408333 regarding not understanding Micheal Kissi's response.
Can you help on this please >
deank
Fixes: 14
Hi @login
Apologies for this, I will take a look into this for you, and update you shortly. I've added this to my diary for tomorrow once I have an update.
login
Update on lrs.
There has been an ongoing [-Censored-] up with account that I daren’t change anything at the moment in case it further causes confusion
Mads
Fixes: 79
Hello @login, I can see the above issue is resolved in relation to the question number 18408333. With regard to line rental saver you should now be able to add this onto your account via the online member centre or calling our Customer Options team on 0800 013 2632.
login
Madly
No one has explained the comments in 184083333 I still am in the dark as to what it means.
This being the case how can you say the situation is resolved?
Warwick
Fixes: 29
Hi @login
Apologies if the comments were not made clear for you, I have had a look through them and responded via the ticket on the account here
I have checked on your account and you should be free to process a Line Rental Saver order should you wish.
login
Warwick
Unfortunately the link you left me offering a reply comes up with
CANT FIND PAGE
MatthewWheeler
Fixes: 479
Sorry to hear this.
We've tested the link and it appears to be working okay.
Can you try again?
 Matthew Wheeler
login
Hi Matthewwheeler
Tried again and same fault persists.
Gives the option of visiting a wizard but his spells must have run out
and was of no help.
But thanks for responding
