im at my usage limit HOW
- My Account/Billing
- im at my usage limit HOW
06-08-2012 7:18 PM
i also received an email the other day to say iv nearly reached my 10gb usage for the month how can i check this as i do not download or anything i pretty much log on to check my emails go on facebook and occassinally go on ebay i have ever had thiss before with talk talk i should have never changed
Message 1 of 6
(1,329 Views)
5 REPLIES 5
Re: im at my usage limit HOW
06-08-2012 7:42 PM
"how can i check this"
Log in to your account and under "My Account" you'll see "View My usage". There are options to check usage total and a daily breakdown.
Message 2 of 6
(431 Views)
06-08-2012 7:50 PM
iv just checked it and it says there is quite a bit of usage through the night which i dont use my computer through the night cos im asleep lol im confused!
Message 3 of 6
(431 Views)
06-08-2012 8:44 PM
There will be a nominal amount of usage overnight (normally in the kb range) due to the router keeping the connection alive. Overnight usage doesn't count towards your montlly allowance so wouldn't be causing you to get close to your limit.
Message 4 of 6
(431 Views)
07-08-2012 2:40 AM
Does your router have Wifi or not? If it has wifi, does it have any authentication enabled? Best to enable WPA2 authentication and change the pre shared key asap as you could have someone leeching from your connection.
If no wifi and just a wired router, then does anyone else have access via your pc or another? Change your pc's login password, nearest and dearest is watching something at night wasting your bandwidth.
FTTP 500 regrade from Tues 28th November
Message 5 of 6
(431 Views)
09-08-2012 9:13 AM
If you have an iPhone or iPad, they could be backing up to the cloud, perhaps?
Message 6 of 6
(431 Views)
