http://failed.billing.plus.net/apps/payment/failed constant redirection on any http sites
kerrycarol
Re: http://failed.billing.plus.net/apps/payment/failed constant redirection on any http sites
Hi, I'm having the same issue again as I was having previously, it has come back and unfortunately hasn't resolved
Fixes: 47
Hi @kerrycarol,
I'm sorry to hear that you're experiencing this issue again. I've changed some settings on your account now, which should resolve this issue. If you're still experiencing issues browsing, please could you also try performing a factory reset of your router?
To carry out a factory reset you'll need to take a look at the back of your Router and you will see a small pin-sized hole, just above and slightly to the left of the power button. The hole will be marked by the word "RESET", written just below it. Please get a pin or needle and hold it in this hole for around 5-10 seconds until the light on the front of the router goes green. After this release the pin and wait about 4-5 minutes for the Router to reconnect.
If any issues persist after this point, please let us know so that we can investigate further.
 Alex H
kerrycarol
Hi I've tried all this previously and non of it worked @Gandalf managed to contact someone on the technical team to get the billing flag removed and that fixed it instantly.
Fixes: 854
Hi @kerrycarol
This should be sorted now, can you retest and let us know how it goes?
kerrycarol
Hey, thank you it seems to be working fine again. Thanks again for the help
Fixes: 854
Glad to hear that!
Sorry that this had happened again.
Rapthorne
Anyone able to press the magic unrestrict button again? Spoke to a lady on the phone about my ongoing double-billing issue and she said she unrestricted me, but I'm still having issues
CPU: Ryzen 7 1800X @ 4GHz
GPU: Gigabyte Windforce GTX 1060 6GB
Ram: 16GB Corsair Vengeance LPX 3200MHz
Case: Red/Black NZXT S340 Elite
jellybeanz
I'm sure it'll come as no surprise to anyone in this thread that it's happening AGAIN this month:
The connection has timed out
The server at failed.billing.plus.net is taking too long to respond.
Have you lost all of your techie staff or something? Seems odd that this problem is still occuring months later...
Rapthorne
@jellybeanz
No staff around on the forums at the moment, but I managed to get it fixed on the phone.
Call their customer service line( 0800 432 0200 ), and make sure you go to the Technical Support, and NOT their customer support (customer support don't have access to the right systems to fix the issue, I was told)
Wait time is about 25 minutes, though 😕 but once they answer, it's essentially a one-click fix for them.
The issue is that their billing system upgrade went very wrong. I myself have been double-billed since November, but there's no quick fix when the system they implemented is on a national scale, so I've resigned myself to having to call up plusnet every month when the billing fails.
Fixes: 47
Hi @jellybeanz,
I can see that you have thanked @Rapthorne's latest comment regarding this issue - are you still experiencing any problems or has this now been resolved?
 Alex H
jellybeanz
Unfortunately due to disability I am unable to use the phone, so I am still waiting for the main website to be unblocked so that I can make a payment. Surely it would make sense to whitelist plus.net/pay for everyone regardless of payment status.
Fixes: 854
I'm sorry to hear this.
I think I've sorted your account out for you now, could you let us know how it goes?
jellybeanz
@Gandalf
Thank you, I can access the main site and payment page now. However, when I try to make payment, I get the following message:
There's currently a problem with our system, please try again. If you continue to have problems, please contact our Support Team on 0800 432 0200
Fixes: 854
Thanks for getting back to us, are you able to try a different device or browser?
kerrycarol
Hello again @Gandalf, sorry to be a bother but the issue is back and I was hoping you would be able to fix it? Thank you in advance! Smiley
