changing isp
- My Account/Billing
- Re: changing isp
changing isp
28-07-2016 11:30 AM
i have placed a order with sky and sky have told me there having problems due to bt/plusnet and cant transfer it
is this plusnet trying to get there £30 fee or just stop me leaving ?
Re: changing isp
28-07-2016 11:31 AM - edited 28-07-2016 11:44 AM
We wouldn't intentionally prevent you from leaving if that's what you wanted to do.
Leave that with me for now, I'll have a look over your account and get back to you.
I've had a look over your account and phone/broadband assets and can't see any reason why Sky shouldn't be able to take the service over.
I can see that we received a broadband cease notification yesterday, that would appear to be an attempt to take over the broadband asset, however we have had no notification against the phone line.
Then at 4am this morning, our suppliers advised us that the broadband order had been cancelled.
Are you taking both your phone and broadband to Sky? As they would usually place a simultaneous order, to take over both services at the same time to avoid you experiencing a loss of service, so if you are taking both to Sky, it's odd that a broadband cease was raised but no phone transfer.
I see you've contacted us this morning before making this post, and advised you'll be speaking to Sky about this again. Are Sky able to give you any more information about what specifically is causing their order to fail?
I appreciate they have advised "They're having problems with us/BT" but I'm not seeing anything on our side that should be causing problems.
Re: changing isp
28-07-2016 12:01 PM
i am moving everything to sky for plusnet line and there had problems for weeks with taking over lines from bt owned ips sky said the only way to move forward with my order thats on hold is to cancel plusnet and them to take the line but plusnet will charge me £30.00 cessation fee for that so wave the fee and let me
Re: changing isp
28-07-2016 12:06 PM
If Sky place the correct type of order (gaining provider led transfer) rather than transfer the broadband on it's own, there should be no issue. Unfortunately we've seen other ISPs placing the wrong type of orders but really they should be following Ofcom guidelines. As you're moving to a non-BT provider on Sky's LLU network, the £30 will apply.
Re: changing isp
28-07-2016 12:09 PM
plusnet is llu
so £30 charge is a blackmail fee stay with bt or be hit with a charge ?
Re: changing isp
28-07-2016 12:15 PM
Plusnet provide on the BT network (Basic Single Line), where as LLU providers such as Sky and Talktalk generally provide on LLU (Local Loop Unbundling/MPF lines).
This basically means that although some of the connection will run along the same Openreach maintained copper lines, LLU providers also have their own equipment in the exchange, unbundling themselves from the rest of the 'local loop'.
The cessation fee would be applicable when moving from us to an LLU provider:
https://www.plus.net/help/my-account/charges-for-removing-broadband/
When would I have to pay it?
You'd only need to pay the charge if the broadband service is being taken off your phone line. Typical reasons for this are:
- the phone line that your broadband's on has been cut off
- you cancel your broadband account without switching to another provider
- you switch to a provider who uses their own network (like a cable provider)
- you move to a provider who uses their own equipment in your exchange (often called Local Loop Unbundling)
Re: changing isp
29-07-2016 9:39 AM
Facinating to see that virtually all the negative comments regarding cessation fee relate to "Plusnet"
https://blogs.which.co.uk/technology/broadband/hidden-broadband-cessation-charges/
Re: changing isp
29-07-2016 10:01 PM - edited 29-07-2016 10:03 PM
they waved my fee after few calls
and the others who are also partly owned by bt group
Re: changing isp
on 29-07-2016 10:53 PM - last edited on 29-07-2016 11:20 PM by Mav
Moderator's note by Mike (Mav): CSA name removed from attachment as per Forum rules
