can't make changes
stuck
can't make changes
Plusnet took over my landline recently, the transfer happened on 4 Aug 2023.  I want to add (free) voicemail but when I log in I get:
An error has occurred
You can't change your products for the moment, you already have a product change in progress.
Does that mean that even though Plusnet has my landline now, the change is still in progress because there is a some sort of 'cooling off' period after the transfer?  If so how long will it be before I can tweak the options on my phone line?
Or, as implied by other topics on this forum that also quote an error like this, it's just Plusnet's systems lagging behind reality and it needs a staff member (perhaps @willcutforth or @Gandalf ) to manually intervene?
11 REPLIES 11
198kHz
Fixes: 42
Re: can't make changes
@stuck wrote:
...it's just Plusnet's systems lagging behind reality and it needs a staff member (perhaps @willcutforth or @Gandalf ) to manually intervene?
Yes, it's long been one of Plusnet's speciality features, and will require manual intervention.
BT technician (Retired)
Fixes: 1,645
Hi @stuck
It looks like there's a little bit of lag with updating your account in one of our systems.
The change is scheduled to complete on your next bill date, so that message should go away then.
Let me know if there are any further issues.
stuck
@Gandalf wrote:
...The change is scheduled to complete on your next bill date, so that message should go away then.
OK I'll wait until then (but it would nice to have the voicemail sooner than that).
Fixes: 1,645
Yeah sorry for the wait. Sad I considered forcing the change through, but that would likely have caused complications in the systems and thus further issues.
stuck
@Gandalf wrote:
...that would likely have caused complications...
OK, waiting sounds preferable to the alternative you set out.
stuck
@Gandalf I forgot to come back and say that, as you said, once my next bill went through, I was able to add the free voicemail option.
Thank you for explaining things.
stuck
@Gandalf  Umm, today I find the same error message:
You cannot make any changes to your account while there is a phone order in progress.
is displayed when I log into my account.   I've made no changes since I added the free voicemail service (around 20 Aug).  The voicemail works as expected and I'm beyond my Sept billing date so what's going on?
Please can this message be cleared?
Fixes: 1,491
Moderators Note
This topic has been moved from Home Phone to My Account / Billing
Fixes: 1,645
That's cleared for you now. Sorry to see it was stuck again. Let me know if there are further issues.
stuck
...stuck...
😃 I see what you did there.
Yes, all OK now.  Thank you for the quick action!
Fixes: 1,645
Haha that was entirely by accident. Seems that subconsciously I’m a very witty guy. Cheesy
