White Screen of death
- My Account/Billing
- Re: White Screen of death
30-01-2019 8:47 AM
30-01-2019 8:53 AM
30-01-2019 9:57 AM
30-01-2019 11:31 AM - edited 30-01-2019 11:49 AM
@JonoH wrote:
Let us know how that goes, please
@JonoH I successfully logged in to the portal this morning
Went to 'Billing' and received this:
Clicked 'Try Again' and after 30 odd seconds Billing page opened.
I closed down and restarted Firefox, Logged back into the Portal and subsequently Billing with the same results as above.
30-01-2019 11:54 AM
What time @Strat?
30-01-2019 11:59 AM - edited 30-01-2019 12:00 PM
@JonoH About 15 minutes ago.
30-01-2019 12:29 PM
I tried again at 12:22.
Same procedure and error message.
Finally opened Billing at 12:25.
30-01-2019 2:03 PM
Hi @Strat,
We're currently unable to replicate the issue with any other customer and are looking for more examples. Now it has opened, let us know if anything changes.
30-01-2019 2:18 PM
I logged into my account at about 14:10 hrs & the bills, calls & questions links all worked.
31-01-2019 3:44 PM - edited 31-01-2019 3:46 PM
I have noticed that my Firefox incurred a substantial update on the 29th of Jan and the error message I received in my post here was generated by the updated Firefox and could be a 'known problem'.
31-01-2019 4:55 PM
@Strat are you able to see if rolling back to the previous FF stops it happening? I can't install your current version to try it atm.
Ex-Broadband Service Manager
31-01-2019 6:57 PM
@Kelly I rolled back to previous FF version and I just get the white screen below the links line with 'Logout' on the end.
Then I let FF update and tried again and the protocol error popped up on the white screen after clicking 'Billing'
01-02-2019 9:04 AM
So you get the menu, but nothing beneath it? That's slightly different to what we were seeing earlier as the menu wasn't rendering either. Do the menu links do anything? If you grab the source of the page, does it look cut off? Could you save it and send it over? Sorry for the hassle with having to roll back. Do you have an antivirus or similar protection program running? If you try with that disabled, does it work?
01-02-2019 9:22 AM
If you hit F12 when on the page with the white screen and look at the console tab, are there any interesting errors? You might need to refresh the page once the console tab is open to see any errors.
01-02-2019 11:55 AM - edited 01-02-2019 12:04 PM
Correct
They all work as expected apart from the Billing one which throws up the Protocol error after half a minute or so.
I'm not familiar enough with HTML to judge the page source but I have attached it.
Disabling my Kaspersky Total Security makes no difference.
Suggestions please on how to send you the source page.
I tried copy and paste into a txt file but file attachment doesn't like it and zipping is unacceptable also.
