When is an 'upgrade' actually a downgrade?
elementaltm
I need assistance to determine if upgrading from: "Force9 Broadband Your Way Option 4" to "Plusnet Extra" is in my best interests, after all traffic management and prioritization seem exactly the same...
I did start to upgrade my account via. the website but hesitated when it didn't seem to give the the option to choose the "Plusnet Pro Add-on"... does this option become available to me after I upgrade to Plusnet Extra?  Huh
Also I currently have a static IP but Plusnet Extra only allocates dynamic IP's unless I upgrade to the Plusnet Pro Add-on. Does this mean a forced changed in static IP?
Lastly I currently have "Max Premium"  upgrade for faster upstream speeds (up to 832kbps) and a higher priority on the BT Wholesale network. Would  I loose this by this upgrade?
Thanks in advance. e.tm
KABOOM!
Fixes: 43
Re: When is an 'upgrade' actually a downgrade?
Traffic shaping on Extra is not exactly the same as BBYW 4, the non-interactive protocols like P2P are more restricted in the evening peak hours. However the product is considerably cheaper and offers an additional 20GB bandwidth allowance.
You wouldn't lose anything if you upgrade from a legacy product. Your static IP and Max Premium will be retained. Both options are available on Extra anyway. The Pro Add-on can't be selected within the Product Change process. Once the new product is live (next billing date) the Pro Add-on becomes available on the Add-ons page. It can be selected at any time and takes effect almost immediately. A pro-rata charge for the rest of the current month is added to the following month's bill (along with the £5 charge for the upcoming month). The pro-rata charge will be the full amount if the Add-on is activated on billing date.
Changing product seems a good move to me, especially with the Pro Add-on. You get more bandwidth, and line speed at all times for a cheaper price than you are paying now.
David
pierre_pierre
and although you keep your features, it is best to do a manual contact to request that, the auto has been known to drop them, Adam nornaly does it OK
elementaltm
Thanks spraxyt and pierre_pierre. How do I contact Adam directly? which team is he in? Smiley
KABOOM!
pierre_pierre
the forum support team, he will be on tomorrow
Adam Walker
Plusnet Support Team
Service Status :: RSS :: Email
elementaltm
Ok thanks, I'd be grateful if you also could keep an eye out for him and pass him my way.
KABOOM!
Fixes: 43
There were problems with the automated Product Change process at one time when moving from legacy products but it should work OK now. I used it when I changed from PAYG to Extra and it worked fine.
David
elementaltm
So what's the general consensus then, to use the online tool? I can't afford anything to f'up.  Tongue
KABOOM!
Fixes: 57
I would use the automated tool then follow up with a question asking that the fixed IP be retained.
Regarding Max Premium - with the new product you may be better going for an uncapped upstream on ADSL2+
Does your exchange show as having 21CN enabled http://usertools.plus.net/exchanges/
Finally - if you make the request with a couple of weeks before your month end you will have time to ensure everything is in shape before it happens
elementaltm
Unfortunately my exchange THTAD is not 21CN enabled. Where does that leave me?
KABOOM!
Fixes: 57
If you need the higher upstream then you will need to retain the Premium option.
I don't remember this coming up before so I would wait for a rep to respond on Monday
In the meantime I will flag this thread up
Fixes: 8
I upgraded from PAYG to Extra with Pro add-on and I also have Max Premium. There was no issue with the Max Premium and I didn't have to do anything about keeping the same static IP either.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
elementaltm
Quote from: Oldjim
Thanks, Oj. Smiley
KABOOM!
Fixes: 4
edit: Removed (Sorry Adam !)  Embarrassed
Fixes: 32
elemental.tm,
For account changes such as this I'd recommend raising a ticket which I can see you've now done anyway....
Let me know if you encounter any problems from here.
 Adam Walker
