When I reach my max download allocation
- My Account/Billing
- When I reach my max download allocation
26-08-2010 4:20 PM
Can someone guide me through what to set, I've tried to set it but didn't appear to work
many thanks
Re: When I reach my max download allocation
26-08-2010 5:07 PM
and set it like this
Note - this doesn't cut you off it just stops you getting charged extra
30-08-2010 2:46 PM
30-08-2010 4:22 PM
30-08-2010 4:38 PM
30-08-2010 7:44 PM
Also it's probably not a good idea to change the value (downwards) when usage is close to an additional-charge threshold, parts of the billing system might be out of step with others for a while. This is all speculation on my part but it's the approach I'd use.
When the revamped tool was introduced I changed my spend limit several times to check it out and nothing untoward happened on my account.
31-08-2010 3:44 PM
31-08-2010 5:02 PM
I've just checked you account and it's definitely set not to go over your package price.
As far as the wording goes I'm getting the guys responsible for the application to give me an explanation for it.
Jojo
31-08-2010 5:32 PM
With regard to the text on this page I have raised a problem (63306) to either have this removed or defined, so will post more information as soon as I know more.
Jojo
31-08-2010 6:55 PM
02-09-2010 2:56 PM
02-09-2010 3:48 PM
If you want me to set it, I can do it for you this end now if you like?
Jojo
02-09-2010 4:01 PM
02-09-2010 4:04 PM
No worries, I'm willing to take the fall for all you guys if necessary.
Data cap set.
Jojo
02-09-2010 4:07 PM
