Well done Plusnet
Roderunner
Well done Plusnet
I have just uodated my profile to vision impaired, and got confirmation by email I was unable to read.
2 REPLIES 2
mystreet1
Seasoned Pro
Fixes: 7
Re: Well done Plusnet
I might be stating the obvious, but how did you update your profile to vision impaired?
Can you not increase the font size and or display settings to one's that you can see?
Was a member for years, but moved from PN fttc to fttp from an AltNet. Getting 940Mb up and down. Happy to stay on here and try to help others. 
Roderunner
It quite simple and I bet you have done it also. You stumble accross itt when looking for some other thing.
Thank you.
