Webspace transfer to Greenby
FIXED- Subscribe to RSS Feed
- My Account/Billing
- Re: Webspace transfer to Greenby
10-09-2025 6:55 PM
I was one of those people that had free webspace as part of my account.
I thought it was meant to be transferred over to Greenby.com when they made the change to no providing directly.
When I attempt to login to Greenby it doesn't recognise my account details. Was there something that I should of done ?
Fixed! Go to the fix.
10-09-2025 7:18 PM
Have you had notification from Greenby that your account has transferred ?
10-09-2025 7:34 PM
@Ken555 From other posts about this the general impression is that users with webspace are likely to be the last ones to be migrated to Greenby. At present I believe only Metronet emails have been migrated so it could be quite a while before webspace users are moved. Months or sometime next year has been mentioned but these are probably complete guesswork. Until you are contacted by Greenby nothing has changed.
11-09-2025 7:57 AM
11-09-2025 9:42 AM - edited 11-09-2025 9:46 AM
I should of said that my webpage has disappeared and the webspace option has gone from the member centre.
I wonder if its something that's happened when I renewed my contract, early, with Plusnet. It was due to stop on the 12th September but I went online and renewed it at the beginning of the month.
I can still FTP into the area and all the files are there.
11-09-2025 11:03 AM
@Ken555 Not sure what you see, but I can see your web page fine - webspace bits on the portal haven't moved.
