Web Site Tips
- My Account/Billing
- Re: Web Site Tips
Web Site Tips
08-06-2007 5:30 PM
Does anybody have any tips or suggestions how i could attract more referrals on my web site
www.shetlandstuff.co.uk
Re: Web Site Tips
08-06-2007 6:00 PM
Re: Web Site Tips
08-06-2007 8:51 PM
Re: Web Site Tips
09-06-2007 6:04 PM
Re: Web Site Tips
12-06-2007 2:47 PM
As you are no doubt aware Plusnet have a large number of referal banners, buttons and text links which you can place on your site. I have them on several pages on my site. Make a note of the referal link, then you can create your own buttons and banners which will link to the referal scheme.
I even include my own banners in emails I send out.
All the buttons and banners in the world won't do any good if your site can't be found by search engines but again Plusnet can help. Somtime back i found a brilliant tutorial in the help section / websites which explained how to alter the code in your pages to make them more searchable. It has worked for me and my site is usually listed highly in google and msn etc.
Sorry I don't have the link to this tutorial but i'm sure you will find it easily.
Good luck.
Re: Web Site Tips
12-06-2007 3:18 PM
Just had a quick look at your site and see that you already have banners in place however I was surprised to note that on the home page, in the google adds section, top of the list is Plusnet. Looks good but the link actually takes you to the Talk Talk website.
If you want to make money from the referal scheme I would get rid of the other links to the other ISP's and concentrate on promoting Plusnet either through their banners or some you create yourself.
The Plusnet links on other pages are great.
Re: Web Site Tips
15-06-2007 6:54 AM
Make the banner ads pop in a new window
Add more keywords
change the generator tag from Web page maker
Add a desription tag
add an index tag & robots return tag
Re: Web Site Tips
15-06-2007 9:40 PM
Re: Web Site Tips
16-06-2007 9:15 PM
The best advice, as has already been noted, is to create your own original content. You could create a "Broadband" section in your links on the left and have a separate page explaining why you recommend us.
Re: Web Site Tips
18-06-2007 2:48 PM
Quote from: arlehaven Hello, back again,
I think that you can remove TalkTalk from the GoogleAds list (if you wanted to keep the ads, but just remove specific ones. Not sure how to do it (or even definite that it CAN be done), but I'm sure I heard that you can remove specific ads if they offer a competitors product etc.
Anyone know if it can be done, and how to do it?
