View my usage
St3althM4ster
View my usage
hi my view my usage has been stuck on this for the last 2 days..
Sorry, there's nothing to show at the moment.
This might be because your account is new, or your usage has been reset for a new billing period.
It can take up to 2 hours for your usage to show up - please try again later.
1 REPLY
Re: View my usage
If you drop the connection via the router's interface then reconnect that should start usage showing again - please let us know if not though.
