View my usage - incorrect percentage?
fhstudios
Looking at 'View my broadband usage' - the 'Summary' tells me I have used 8.3GB of my 60GB allowance, the 'Usage Breakdown' tells me I've used 100%Huh?
Fixes: 10
Re: View my usage - incorrect percentage?
You're misreading it - the second table is a breakdown of your usage so far - if it didn't add up to 100 it would be wrong!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
fhstudios
Cheers!
