View my usage.... a suggestion
- My Account/Billing
- Re: View my usage.... a suggestion
28-03-2012 9:43 AM
The existence of two measures GB and MB in the same table as presented by PN with the requisite annotations is the problem, as also is the need to convert info to either MB or GB to make analyses.
I suggest to PN management, therefore, that all usage should be standardised to GB to, say, three decimal points.
28-03-2012 10:01 AM
28-03-2012 12:02 PM
28-03-2012 3:44 PM
28-03-2012 9:05 PM
Would you consider trying a Greasemonkey script that converted all MB numeric values to GB and omitted the "requisite annotations"?
28-03-2012 10:20 PM
28-03-2012 10:23 PM
What's the worst that can happen?
29-03-2012 9:58 AM
If not me someone might want and feel more able to use?
29-03-2012 5:22 PM
So, here's a greasemonkey script that seems to work OK for me. However I'm not sure about the global side effects.
// ==UserScript==
// @name Broadband Usage in gigabytes
// @namespace https://portal.plus.net/view_my_broadband_usage/index.php
// @description Remove UOM from usage figures
// @include https://portal.plus.net/view_my_broadband_usage/index.php?&strAction=PERIOD
// ==/UserScript==
var currentUom, currentCell, currentUsage;
var targetCells = document.getElementsByTagName('td');
var targetH3 = document.getElementsByTagName('h3');
for (i=0; i < targetCells.length; i++) {
if (currentCell = targetCells.childNodes[0].nodeName !== 'STRONG') {
currentCell = targetCells.innerHTML;
else {
currentCell = targetCells.childNodes[0].innerHTML;
currentCell = currentCell.replace(/\s/g, '');
currentUom = currentCell.substr(-2);
currentUsage = parseFloat(currentCell);
switch (currentUom)
case "KB":
currentUsage = currentUsage/1000/1000;
targetCells.innerHTML = currentUsage.toFixed(3);
break;
case "MB":
currentUsage = currentUsage/1000;
break;
case "GB":
currentUsage = parseFloat(currentUsage);
break;
default:
currentCell = currentCell;
for (i=0; i < targetH3.length; i++) {
if (targetH3.innerHTML === 'Key:') {
targetH3.innerHTML = 'Note:';
targetH3.nextElementSibling.innerHTML = '<li>All figures are in gigabytes (GB)</li>';
Edit - updated the script code
30-03-2012 6:10 PM
30-03-2012 7:35 PM
1. Install Firefox
2. Install Greasemonkey add-on to Firefox
3. In Firefox, select Tools > Greasemonkey > New User Script...
4. In the window that appears enter a name for this script, eg "Broadband usage in gigabits" and click OK.
5. A page should open in your text editor, eg Notepad.
6. Copy the entire text from the code box in my previous message in this topic, and paste it into the window opened in step 5, replacing the previous contents.
7. Close the text editor, saving the changes.
8. Go to the Plusnet Broadband usage (for the current period).
9. Optionally, tell me where I've got it wrong
FYI. There are other ways to achieve the above. Also, I believe that Chrome supports userscripts without an add-on, but I've never tried it.
30-03-2012 8:40 PM
Quote from: JohnJ 9. Optionally, tell me where I've got it wrong
It doesn't work!
30-03-2012 8:43 PM
Could you be a little more specific? For example, are some of the values changed and not others?
30-03-2012 8:47 PM
30-03-2012 9:02 PM
The script should also add a message at the bottom of that column about the figures being in GB.
