View My Usage - Nothing to Show
tim11pop
Hi all,
Bit of an odd one here. I'm on the PlusNet Unlimited Fibre option and for the first few weeks since I received the internet, the "View My Usage" page showed my usage. However it stopped working after the second month. Always saying the "Sorry, there's nothing to show at the moment." message.
I was curious how PlusNet recorded this information as I have since changed my router for a bit more... powerful one.
10 REPLIES 10
spraxyt
Resting Legend
Fixes: 75
Re: View My Usage - Nothing to Show
You are probably affected by the bug mentioned in this Service Status post. The problem has been ongoing since 15/07/2013.
David
bobpullen
Fixes: 316
Should be fixed now. Shout up if it isn't.
waynepyrah
Mine is still broken Bob
This might be because your account is new, or your usage has been reset for a new billing period.
It can take up to 2 hours for your usage to show up - please try again later.
If you have any questions about your usage, please see our View My Broadband Usage FAQ or contact our Support Team."
KevH
Still broken for me. Any update on when this is going to get fixed?
orbrey
@waynepyrah and @KevH, both of your current connections have been ongoing since before you were last billed. If you drop the connection via the router's interface then reconnect your usage should update within the next hour or so.
Hope that helps.
KevH
Matt - many thanks. Will do this tonight.
I'm on an unlimited package but hate to think how much data the teenagers have got through during the summer holidays!
waynepyrah
tried disconnecting again... watch this space...
view usage only worked for a few weeks after joining then nothing since, apparently its a known issue lol
adamwalker
Fixes: 221
That's the beauty of unlimited, you don't have to worry about that Smiley
@waynepyrah
As Matt mentioned in reply #5 It should be sorted so just try dropping your connection and all should be well
 Adam Walker
tim11pop
Aye, not fixed on my end either.
waynepyrah
Still bust
