VMBU showing 2 months?
Legend
Fixes: 253
Dunno if anyone else has noticed this, but I think VMBU is broke.
It is showing two months usage as one, and appears not to have picked up any usage overnight.
Comments?
20 REPLIES 20
trishah
Re: VMBU showing 2 months?
I was just about to report this, mine is showing Aug 7 to Oct 8 must be a fault
orbrey
Hi guys,
Really sorry about this, it is indeed a problem and one we're aware of and investigating (the reference is 72605). We'll make sure to update you as soon as we have any more information.
jelv
Fixes: 10
I watched over two hours of HD iPlayer yesterday (during peak time) and the usage is showing only 172.62MB!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Strat
Fixes: 565
Just to associate my account with this problem.
Your current billing period
Aug 08 2012 - Oct 07 2012
orbrey
Thanks Strat, though I believe the developers working on the issue have already identified everyone affected - as per the service status that's been posted we're in the process of fixing it all now, should be done by around lunchtime.
jelv
Fixes: 10
Is the same issue affecting under recording of yesterday's usage or is that a different issue?
orbrey
Hmm, I asked about that and it looks like it's a separate issue. We don't yet have a problem raised on that one but I'll see what I can do there.
Strat
Fixes: 565
My VMBU seems to be fixed now :)...more or less, with an extra 2 days in the Aug/Sept period.
Billing period: 08 Aug - 10 Sep
Billing period: 08 Jul - 08 Aug
Billing period: 08 Jun - 08 Jul
Gus
Not fixed here as yet
Aug 09 2012 - Oct 08 2012
Thankfully I had 9 gig spare from last month, so unlikely to be capped unless it takes too long
FTTP 500 regrade from Tues 28th November
orbrey
It's running now and I believe should be completed within the next hour, apologies for the delay.
kmilburn
My current billing period is right,  but there is an oddity with the previous months...
Current billing period: Sep 01 2012 - Sep 30 2012
Summary of usage in previous months
Billing period: 01 Sep - 01 Sep
Billing period: 01 Aug - 01 Sep
Billing period: 01 Jul - 01 Aug
orbrey
@kmilburn Not sure what's happening with that one, that does look odd - I'll check on it tomorrow morning and update you then.
Regarding the usage resets, those are still going on I'm afraid but they should finish tonight. The majority of those affected should have been reset by now though. Sorry it's going on so long.
I'll be back to confirm in the morning that everything's all done Smiley
Legend
Fixes: 253
Think there's still a problem - I don't seem to have any overnight usage recorded.
jelv
Fixes: 10
Ditto - and I was up listening to the tennis.
