VMBU - previous months borked - again!
Fixes: 8
Just spotted that https://portal.plus.net/view_my_broadband_usage/index.php?&strAction=PERIOD#history_three_month is showing rubbish again with duff periods and no data.
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
Fixes: 116
Re: VMBU - previous months borked - again!
I've not had anything recorded for the past 3 days either
Will Moderate For Thanks
Nothing so far today, nothing Friday or Saturday, and only 30.11MB last Thursday, suggesting it stopped working in the early hours of the 23rd.
Fixes: 50
The first 9 days (8th to 16th inc) of my current billing period are zero but it then started recording usage.
However I rarely look at it for two reasons...1 - I'm on unlimited and 2 - I don't really trust it.
Customer and Forum Moderator.
Fixes: 8
It's essential information if you are considering moving to an ISP on an account type which is not unlimited.
Fixes: 57
Much better to track your own using NetworX
Fixes: 8
NetWorX does record usage by the SamKnows box or any other device not using NetWorX.
Fixes: 57
Can't you set it up to monitor the router
MattyC
Champion
Fixes: 46
Hi Jelv, thanks for reporting this.
I've just raised the problem now. For my colleagues; the incident reference is 87329.
Matty
