Usage limit reset?
richandsian
Usage limit reset?
I'm sure I had a usage limit set, but apparently I've just gone over the 120GB cap and been charged... off I go to check I hadn't accidentally left it at an extra £5 only to discover there wasn't one set.
Am I going mad or would this have been reset, perhaps when the cap moved from 80GB to 120GB?
RPMozley
Re: Usage limit reset?
Unfortunately the cap is removed after a product change. There was a discussion about this earlier here in the Feedback section I think (can't find the link for it at the moment on my mobile device but hopefully someone else will find it and post it up for you).
Fixes: 57
This was one but I am sure there were others http://community.plus.net/forum/index.php/topic,105766.0.html
richandsian
Thanks.
Good, honest broadband... from Yorkshire I guess!
Plusnet Staff
Plusnet Staff
Fixes: 159
Let me see if we got anywhere with this and get back to you.
 Chris Parr
 Plusnet Staff
Fixes: 21
At the risk of being told off, bump  Roll eyes
Plusnet Staff
Plusnet Staff
Fixes: 159
I hadn't forgotten, just not had chance to speak to the developer I needed to yet.
 Chris Parr
 Plusnet Staff
Plusnet Staff
Plusnet Staff
Fixes: 159
Still on my radar to do!
 Chris Parr
 Plusnet Staff
