Usage limit reset?
- My Account/Billing
- Re: Usage limit reset?
Usage limit reset?
02-10-2012 1:42 PM
I'm sure I had a usage limit set, but apparently I've just gone over the 120GB cap and been charged... off I go to check I hadn't accidentally left it at an extra £5 only to discover there wasn't one set.
Am I going mad or would this have been reset, perhaps when the cap moved from 80GB to 120GB?
Message 1 of 8
(1,362 Views)
7 REPLIES 7
02-10-2012 2:40 PM
Unfortunately the cap is removed after a product change. There was a discussion about this earlier here in the Feedback section I think (can't find the link for it at the moment on my mobile device but hopefully someone else will find it and post it up for you).
That's RPM to you!!
Message 2 of 8
(536 Views)
02-10-2012 2:43 PM
This was one but I am sure there were others http://community.plus.net/forum/index.php/topic,105766.0.html
Message 3 of 8
(536 Views)
03-10-2012 4:40 PM
Thanks.
Good, honest broadband... from Yorkshire I guess!
Message 4 of 8
(536 Views)
03-10-2012 5:37 PM
Let me see if we got anywhere with this and get back to you.
Message 5 of 8
(536 Views)
08-10-2012 3:01 AM
At the risk of being told off, bump
Message 6 of 8
(536 Views)
08-10-2012 9:51 AM
I hadn't forgotten, just not had chance to speak to the developer I needed to yet.
Message 7 of 8
(536 Views)
10-10-2012 8:56 AM
Still on my radar to do!
Message 8 of 8
(536 Views)
