Usage Limit
- My Account/Billing
- Re: Usage Limit
Usage Limit
12-09-2011 6:24 PM
I was under the impression I had set a limit on my account to prevent me from going over the 10gig allowance, I have value package and set my maximum spend to zero after going over the 10 gig on the last day in the previous month. Yet this month I have 3 days to go and it is showing that i have used 10.02gig which is over 10gig right.. but my maximum spend is zero so shouldn't it stop at 10gig ?
Message 1 of 7
(1,282 Views)
6 REPLIES 6
Re: Usage Limit
12-09-2011 6:30 PM
Are you still getting normal speeds or are they chopped right back?
Message 2 of 7
(494 Views)
Re: Usage Limit
13-09-2011 9:48 AM
I can see the note on the account that states your connection has reached the limit. You won't get any extra data charges on there, and the usage will reset for you on the 16th.
Hope that helps,
Hope that helps,
Message 3 of 7
(494 Views)
Re: Usage Limit
13-09-2011 10:08 AM
The system doesn't constantly monitor your line (that would be way too much overhead), instead it gets reports at intervals (15-20minutes?). It would therefore be expected to see it go over the limit a short way before there is an update that takes it over and imposes the restrictions (i.e. it errs in your favour).
Message 4 of 7
(494 Views)
Re: Usage Limit
13-09-2011 10:54 AM
So I will not pay more than £6.49 for my value plusnet package?
Alex
Alex
Message 5 of 7
(494 Views)
Re: Usage Limit
13-09-2011 11:02 AM
Correct
Message 6 of 7
(494 Views)
Re: Usage Limit
13-09-2011 10:22 PM
Thankyou
Message 7 of 7
(494 Views)
