Upgrade your existing fibre at no cost!
VileReynard
All Star
Fixes: 11
Just accidentally discovered that Plusnet have TWO Fibre Extra products (with the same name).
I had the bad one - 120GB limit, max speed 40Gbits/sec, cost £21-99 per month
You can (apparently) upgrade to the good one:-
250GB limit, speed up to 80Gbits/sec, cost £19-99 per month.
I believe the upload speed increases too.
The only downside is that the 18 month contract period gets reset.
1 REPLY
Fixes: 62
Re: Upgrade your existing fibre at no cost!
What do you think this is all about http://community.plus.net/forum/index.php/topic,106965.0.html ; Shocked
Thread locked
