Upgrade to full fibre questions ...
picbits
I'm due for renewal on the 29th July, had an email through with a couple of offers.
One of them was Fibre 145 for £26.99 a month but when I click on the link in the email it says the offer has expired and is now £29.99 / mo. At the bottom of the email though it says "Offers correct at time of printing and valid until your contract end date." ...
Other questions:
Reading through previous threads, I can keep my static IP address, can you confirm if this is a new assigned IPV4 or if I can keep my existing IPV4 address to save messing about with my nameservers ?
Does the Plusnet Hub Two router allow port forwarding (i.e. to my smart home server and email server) ?
The install time can be up to 4 weeks ? How does this affect my renewal ? Do I sign up and continue at the new price on my FTTC connection until the FTTP connection has been installed ?
Will I keep any referal bonuses against my account in either case (not sure if they are still active). ?
Thanks for the help. If all of the above are yes then I'm happy to pull the trigger and move to full fibre. You'll find my account details under dstratten - for some reason I can't log into the forums with that username.
6 REPLIES 6
Fixes: 524
Re: Upgrade to full fibre questions ...
@picbits  can you confirm if this is a new assigned IPV4 or if I can keep my existing IPV4 address to save messing about with my nameservers ?
A static IP assignment is associated with the account and so should remain over any product upgrade. I've upgraded many times and my static IP has always remained.
The HUb 2 does support port forwarding but you can still use your own router if you prefer providing it has an ethernet WAN port. What router do you currently use ?
Can't answer that one, will need a staffer input
Yes
I assume you realise you will lose your landline phone service ?
Fixes: 457
Ring the Customer Options Team on 0800 013 2632 and ask them to honour this offer. This number is normally answered quite quickly. If you don't asl.....
picbits
Currently use a Billion 7800NL (off the top of my head) - should be compatible with most things but getting a bit old now.
Yup - bit of a downside but I have a SIP local number that I rarely use but could get running again. I think my last 100 calls have all been spam to my normal landline. I ended up putting a call screening phone on and not had anything through for months ...
RobPN
Fixes: 13
@picbits
I'm not familiar with that router, but you may find that its WAN throughput is insufficient for the 145 Mbps. deal you're aiming at.
Fixes: 524
@picbits Currently use a Billion 7800NL (off the top of my head) - should be compatible with most things but getting a bit old now.
Whilst it does have an EWAN capability and so will work,@RobPN  is correct, the 7800 seems to max out at around 90Mb according to tests here http://billion.uk.com/forum/viewtopic.php?t=345&sid=1541e57bf1fa923712b656986678f898
and so isn't really suitable for a 145Mb connection.
picbits
Just got off the phone from them and they honoured the £26.99 / month
I'll have to pay the increased rate of £50.80 / month until the FTTP is installed but the good news is that has been booked for the 2nd so only a few days at the higher rate.
Bit of a bummer about the new £3 per month increase every March - this is around an 11% increase each year which is a bit more than the old CPI + 3.9% ...
Hopefully there will be a bit more competition and lower prices in a couple of years when the new contract is out but who knows ....
