Upgrade Fibre
- My Account/Billing
- Upgrade Fibre
Upgrade Fibre
13-01-2015 6:34 PM
I have filled in the product change info to upgrade my fibre does anyone know when the upgrade takes place? Thank you
Message 1 of 5
(794 Views)
4 REPLIES 4
Re: Upgrade Fibre
13-01-2015 6:40 PM
Assuming it is from fibre to fibre - just a product change
It will happen on your next billing date
Message 2 of 5
(426 Views)
Re: Upgrade Fibre
13-01-2015 7:39 PM
Thanks Oldjim yipeee that's tomorrow then
Message 3 of 5
(426 Views)
Re: Upgrade Fibre
13-01-2015 7:56 PM
I hope that the script runs in time then if you have only just done it
Message 4 of 5
(426 Views)
Re: Upgrade Fibre
14-01-2015 2:21 PM
Just to confirm, your package should be showing as Unlimited Fibre Extra now.
Message 5 of 5
(426 Views)
