Under extra features > Pro Addon "remove this bolt-on" doesn't work, never finishes loading
LordFluffeh
when I visit plus.net/AddOns.html and try to remove the Pro Add On by clicking "remove this bolt-on" a white loading bar shows up and never disappears, the same thing happened when I clicked "Add this bolt-on" however it added it and now won't let me remove it, I've tested on android with mobile data and windows 10 with Ethernet to plusnet router
Edit: I meant to post this under My Account/Billing
6 REPLIES 6
BD
Fixes: 86
Re: Under extra features > Pro Addon "remove this bolt-on" doesn't work, never finishes loading
Hi @LordFluffeh, thanks for getting i touch and I'm sorry to hear you're having trouble when trying to remove the Pro-Addon via the member center currently. I've raised a ticket on your account regarding this so we can help you get it removed and if you can please get back to us on their we'll assist you with this.
The ticket I've raised can be seen here.
We look forwards to hearing from you.
tstaddon
I've observed the exact same issue (I enabled it accidentally this morning).
Skye5
Hello, I have the same problem, clicking "Remove this bolt-on" --> stuck with the loading bar on screen, no matter what I try or when I try (various browsers, gadgets and times). Please could you remove my bolt-on? Thank you.
Thrall
Seasoned Pro
Fixes: 23
Try raising a ticket here (Login to your account may be required before clicking on the link)
Fixes: 1,483
Moderators Note
This topic has been moved from Fibre to My Account / Billing
Skye5
Done, thanks for the tip!
